Help need a diagram or picture
StuntingShaggy
Car: 1991 240sx
When I took my motor out I was an idiot and I didn't tag any of the vacuum lines at the back end of the cylinder head. Anyone have a picture of these and where they go into the EGR, fuel rail, etc. so I can finish putting in my new engine? Any vacuum diagrams or pictures will be helpful.
i2ice4m3
Car: COUNTERSTRIKE!
but seriously, if nobody has a picture of it, you can always look at the vacuum diagram in the FSM. Good luck man!
Raxephon
Car: '04 RX8...for the moment...
StuntingShaggy
Car: 1991 240sx
Thanks anlasak, you're a lifesaver.
I'll have some pics and videos up after the swap is complete. Thanks for your support guys!
Raxephon
StuntingShaggy wrote:Thanks anlasak, you're a lifesaver.
You're welcome.
Good luck.
StuntingShaggy
Car: 1991 240sx
Also if you could, the 4 lines coming out from above my butterfly aren't completely figured out. I know 2 go to the canister sitting by my headlight, but where do the other two that are about a foot longer go? It says they go to the PAIRC solenoid valve, unfortunately I don't know where that is haha.
Raxephon
StuntingShaggy wrote:Also if you could, the 4 lines coming out from above my butterfly aren't completely figured out. I know 2 go to the canister sitting by my headlight, but where do the other two that are about a foot longer go? It says they go to the PAIRC solenoid valve, unfortunately I don't know where that is haha.
Maybe this will help a little.
