HELP! need 30mm poprivit on fender flares
twisted99s10
Car: 1989 Nissan 240sx Hatch
1992 Nissan 240sx Sil-camino
1993 Nissan 240sx Coupe
i have spent hours searching the net for just a pair of pop rivet on rear fender flares that are 30mm wide. i can find 50mm and 60mm all day long. my rear tires only sit out about an inch. i would just flare the fender but the car was hit in the left rear and has had body work done. if i roll the fenders the putty is going to crack. any help would be greatly appreciated. thanks in advance.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
You obviously arent looking very hard.
http://www.kgsengineering.com/...d=211
Took literaly 1 second through google, and it was the second option.
And if you are worried about the putty cracking if you roll your fenders, then sounds to me that you need a new shell.
twisted99s10
those are the over fenders. im looking for just flares.
like these but not as wide.
http://cgi.ebay.com/ebaymotors...99559
the shell is a solid shell, but it had a 2 inch deep dent about a foot long and 8 inches tall in the left rear quarter. i pulled most of it out but there is a thin layer of putty to smooth it all out.
That's all you're gonna find. Add some spacers.
They're a PITA to put on. Keep in mind, any drilling is gonna go into putty as well, and these will flex the metal.
They don't fit great either.
blacksrjdm
http://www.ilovebodykits.com/p....html
I dont know how much smaller they are gonna get than that.
Or this:
http://www.kgsengineering.com/...d=227
Or just keep doing some searching, but as far as I see they dont even specify the size of any of them as being 50mm or 60mm or 30mm or whatever.
twisted99s10
yeah none of them specify. iv called about 15 diff companies and asked about it. oh well, thanks guys. i think im just gona try to roll the fender and fix anywhere that cracks. i just had the body work perfect and didnt really wana screw with it ne more.
blacksrjdm
There is also an entire thread dedicated to the flares...If you search you will find.
zerosearch
