Help! Need 20 in Tire Recommendation
courthaven
Car: 2007 Infiniti M35X
Hi all,
Around May I purchased some new rims and it came with Lexani LX-Six tires (255-35-20). Everything was fine at first however after about 5000 miles on them they are horrendously loud. I can't hear a thing. I am just going to break down and buy a new set I guess, but I wanted to see if you had any recommendations for me on a tire that is this size and quiet.
From looking around the forums people seem to be high on these Continental DWS tires, but I did see a review or 2 with someone saying that it is noisy. Any help that you all could provide would be greatly appreciated.
Thanks and have a good one!
kingcnc91
those are comparable to the Nexens that come with all the wheel and tire packages.. they are non-expensive tires and lets just say you get what you pay for.
courthaven
Yeah, that's what I've learned from this experience so now I am just a little leary on other tires this size now and need some advice.
PlatinumM35
Car: 2006 Infiniti M35
Tein H-Tech Springs
Slotted/Cross Drilled Rotors
Wagner Ceramic Brakes
22x9 Status Wheels
Rear Entertainment Aftermarket
15'' RE Audio Subwoofer
Infinity Reference Door Speakers
They're made in a nexen factory then they slap on the lexani name. I will never buy another set of tires from them. I'm have the same issue. I recommend falken fk-452 tires.
06M4.5
Car: 2006 M45
Like Vredestein & Hankook V12's
I have used both and never had a problem with them.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Hankook EVO V12 are awesome!! :dblthumb: Falken 452 are also good!!
moedawg140
Car: 06 M35 S (Adv. Tech)
LI Quad
G37 BBK with H&R DRS
(15mm F, 10mm R)
Focal 165KRX2 (F)
Infinity Kappa 63.9i (R)
Alpine Type-X 10"
JL HD900/5 (sub chnl.)
RF CPCD10-03
Morimoto 4,300K H11
I have the Hankook EVO V12 tires as well. Great tires - definitely better than the OEM Goodyear RSA's I had. However, from what I've been reading, the Michelin Pilot Super Sport looks to be quite the performer - this will be my next set.
EniGmA1987
Car: '06 Infiniti M35 Sport
+1 again for the Hankook Ventus V12 EVO K110 tires.
Stupid long name on them though.
courthaven
Hmm...a lot for the Hankook tires I see. I didn't even consider those.
06M4.5
Car: 2006 M45
The only problem I see with the V12 is they don't make a 235/35/20 which is the size to match with the 275/30/20 tire.
The 245/35/20 is matched with a 285/30/20
I think Vredestein doesn't make a 235/35/20 too
EniGmA1987
235 is a bit small isnt it? I thought 245/35/xx was stock for our width rims?
06M4.5
Car: 2006 M45
It all depends what rear tire you go for. It's best to match the size as best as possible.
Some members are using 225/35/20 for the front.
zerg711
I'm running 245/35 in the front with 275/30 in the rear. The fronts are slightly bigger in diameter by maybe .1 but you can't tell. I am running Continental DWS but I don't drive the M enough to know if it's any good. I only put on 2k miles a year right now :gapteeth:
06M4.5
Car: 2006 M45
I can see the difference
245/35 = Overall Diameter: 26.75 in 679.45 mm
275/30 = Overall Diameter: 26.49 in 672.84 mm
difference is .26 in
The Bodyguard
I ran this size on my M with the WORK wheels..20"x9" 20"x10" 245/35/20"front 275/30/20" rear! They were great for me! :gotme
I ran 235/35/20" front and 265/35/20" rear on my M with the Vossen 20"x9" 20"x10.5"and didn't like the stretch on the front...if Mounted on 20"x9" I would go 245/35/20 if I would do it all over again!!
If you have to match them up, run 245/35/20" and 285/30/20" :bigthumb:
EniGmA1987
If you can see a 1/4" difference in tire size when looking at a car you are either superman or it is probably the suspension leaning more one way
courthaven
Has anyone tried Michelins on a 20 inch rim with good results?
pokerdude
I recently placed the Michelin pilot super sports on my m37-255/40R20. I have about 1000 miles they and are fantastic. Best tires I have ever had. Just came from the continental dw and these blew them away. They stick and corner on rails. Most impressive is their comfort. Ride is significantly improved form the dw and road noise is pretty much gone. It has transformed the car! The tires are very expensive but will worth it.
White-Rush
Car: 06 M35S - Sold
11 M37S - Ran hard and sold
16 Q70S
pokerdude wrote:I recently placed the Michelin pilot super sports on my m37-255/40R20. I have about 1000 miles they and are fantastic. Best tires I have ever had. Just came from the continental dw and these blew them away. They stick and corner on rails. Most impressive is their comfort. Ride is significantly improved form the dw and road noise is pretty much gone. It has transformed the car! The tires are very expensive but will worth it.
Yeah, I can vouch for these tires, very very good at doing their job; and also very dang expensive. But if anyone wants them in some of these popular sizes mentioned above, I don't think they'll have any luck. I looked for a set to go with my Work wheels and they didn't have anything in that size.
06M4.5
Car: 2006 M45
EniGmA1987 wrote:If you can see a 1/4" difference in tire size when looking at a car you are either superman or it is probably the suspension leaning more one way
Please call me Superman :rotflmao
zerg711
^ This is the same guy who claimed he felt a difference with K&N filter. His sensitivity to change is much higher than everyone :gapteeth:
06M4.5
Car: 2006 M45
zerg711 wrote:^ This is the same guy who claimed he felt a difference with K&N filter. His sensitivity to change is much higher than everyone :gapteeth:
and y-pipe
and Uprev
but don't take my word for it :rotflmao
courthaven
Well I learned a little something new about tires and my situation. I went back to the shpe where I bought the wheel and tire package and one of the guys there was swearing that his tires did the same thing. So he suggested that I get an alignment because the tires in the front were feathered and rotate the front ones to the back. I went and did that so now I am going to see what happens. Apparently, I would have to drive on it for a bit so I will see if that helps.
Has anyone had this happen to them?
