nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu Jun 16, 2011 9:19 pm
I know someone post on here having a similar issue, and it ended up being the comp. If its possible to swap with a known working one? If not then check the wiring, make sure there are no corrosion at the coil and PTU. Check the wiring at the PTU, and clean the connectors. its very possible it may be loose or corroded. Do this before the computer, this seems to be the easiest thing to do and may be the problem.
