Someone49 »
https://forums.nicoclub.com/someone49-u29093.html
Sun Jun 19, 2005 10:15 am
Ok here is some basic info on my 240It is a 92 se hatch
Mostly bolt on's header,exhaust,intake,
The background on the problem i have goes like this.
One weekend going to auto-x i overd heated the car on the highway... wtf so i pulled off and popled the hood and the top radiator hose had come of.. So i put it back on filled it back up with coolant let it cool for bout and hour. Drove it home it was fine but missed auto-x. The next weekn sitting in the car my gf said it smelled the same smell it did when i over heated it. So i got out and sure enuff their was a crack in the rad right by top hose. I was able to put some Quicksteel on it for a temp fix untill i got my new radiator. I orderd a koyo oem speck rad with plastic ends. seemed little bigger than oem but not much. Put the new radiator in and still overheating radomly weird.... so i thought it was thermostat put that in still never ran right over heating peroticly. So the last thing i could do was the water pump wich i did yesterday and i filled the coolant back up exactly like the fsm said with the air bleed valve open to let air escape wich i thougth what i had been doing wrong all along . But apprently not because after bout 5 min diving it overheated. I am really stuck and dont know where to go as my next step i have replaced every thing in the system.. i dont see what their is left to do..
Please help
THanks~ANthony
Edit: i have bout 140k mikes on my ka and i am in houston tx
