aidanair »
https://forums.nicoclub.com/aidanair-u84332.html
Sat Jan 02, 2010 4:23 pm
so i havent posted in a while as ive been working on everything myself but i swear my Z is cursed. just to inform you a little of my struggles, i had an alternator go out, my studs on my rear passenger side wheel snap while driving (wheel fell off and rolled away).. and now this. all in 2 months.
I installed an aftermarket A pillar boost gauge yesterday. tapped the line right below the throttle body on driver side that i capped after carbon canister delete. all works great. i also installed NGK PFRB cold range spark plugs. went to fire her up, no good. it turns over but does not combust. not a single cylinder will fire. it just turns over and over, no pop at all. threw codes got 21 and 13. fixed a broken wire on the water temp sensor and tried again, nothing. still throws code 21 and 13. tried a different sensor altogether, same. i pulled a plug and tested for spark and i def have spark. i also smell gas in the cylinder and on the plugs when i pull them and sniff test. please help, i am so lost.
