Dalukebark »
https://forums.nicoclub.com/dalukebark-u159873.html
Thu Apr 29, 2010 9:43 pm
Like I said, my taillight/insturment cluster/corner light fuse keeps popping. It is the 15a fuse, third from the bottom on the right side of the driver kick panel. I recently wired new 4"x6" speakers in the front and believe this may have something to do with the problem (this all started the same day I wired them). I have heard the orange wire on the radio harness is for the illumination circuit, and I've checked and tampered with this but still no luck. Also I have an alarm installed with a circuit to make the taillights and corner lights flicker when arming and disarming, and the fuse on the alarm is also blowing. I really wanted to avoid finding the amperage and putting in a resistor, Id much rather find the problem and fix it right.... Any suggestions?!?!?
