HELP.. My s14 is a killer!!!
shiaokaz
Car: 1997 Nissan 240sx
Hey All
I rencently notice that my car is running rich.. I have to fill my gas (whole tank) around 240 - 260 miles. I thought that S14 for the fuel is around
22 city and 28 highway.
can someone give me some advice or suggestion.also how to fix this problem thank you
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
well how much do u put in when u fill at that mileage?
in the winter my mileage drops like 2 mpg, in summer is get 23-24 mpg in winter now i get 21-22 mpg (mostly city driving) highway boosts it a lot.
but calculate ur mileage on how many miles u drive and then how much u put in and divide
max
shiaokaz
Um..I filled up whole tank ( 14 Gallon)
14 * 25miles (City and Hight) - 350 miles. but I have to refill my gas everything 240 -260 miles.which means, my car only give me 18 MPG..
Do I have to replace fuel pump or anything.. someone pls pls help me outthank ou
Modified by shiaokaz at 11:12 AM 2/5/2005
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
whens the last time u did a basic tuneup?
plugs,wires, fuel filter, distributor?try those things, their under 100$ total
max
wangless
Car: '02 MBP WRX
recently changed my coolant temp sensor and it gave me 50 more mpg... i have a clogged/rusty cooling system
xekushnr
Car: '90 Nissan 240SX Hatch
i hope you meant 50 extra miles to the tank instead of mpg, or im going to have to go buy a new coolant temp sensor.
wangless
Car: '02 MBP WRX
lol yeah... thats what i meant
Fester
Car: S12, CA18DET, T28bb, MT8
xekushnr wrote:i hope you meant 50 extra miles to the tank instead of mpg, or im going to have to go buy a new coolant temp sensor.
hehehe that gave me a good chuckle
sxseguy
Car: Makin' it go faster!
The S14 tank is 17 gallons, and I get about 17 - 18 mpg out of my automatic S14, which means about 275 - 300 out of a full tank, so you're not far off. My car will get worst mileage than a 5 speed, plus I drive the snot out of it! I'm just afraid of what my mileage will be like after I turbo it. Worse mileage + premium gas = thinner wallet.
n00b240
Car: '03 6MT
A quick search will show you that the numbers you are getting are quite normal. Dont worry
shiaokaz
sxseguy wrote:The S14 tank is 17 gallons, and I get about 17 - 18 mpg out of my automatic S14, which means about 275 - 300 out of a full tank, so you're not far off. My car will get worst mileage than a 5 speed, plus I drive the snot out of it! I'm just afraid of what my mileage will be like after I turbo it. Worse mileage + premium gas = thinner wallet.
I see, Thank you so much, but I have done some research , i thought that 240 City is around 21 - 22 and Highway is around 28?
so if 17 * 25 (City and High Way), Should we get somwhere around 350 or so?
n00b240 wrote:A quick search will show you that the numbers you are getting are quite normal. Dont worry
Ya.. I am a total Newbie. but thank you for your advice
Thank you all
J
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Ok here we go. The S-14 has a 16.7 gallon tank. The automatic will technically get better gas milage because it has over drive and in top gear it will run about 300-400rpms less than a 5 speed in 5th gear, you can make up for the difference if you shift gears at like 2500rpms but do you know anyone with an S14 who does that? On a stock S14 I used to get about 360-380miles (city) before the fuel light would come on. I now have no cat and a straight exhaust system, (Hotshot header, 2.5" test pipe and 3" Apexi N1 exhaust) and I can get about 345 miles to a tank, (city) almost 400 (highway). If you are getting crappy milage then change your plugs, wires, and O2 sensors. Also CHECK your fuel injectors and fuel filter.
frapjap
'07 Subaru Legacy
Thats awesome! I almost forgot that the s13 has a smaller tank.
On the highway I get very close to 300-325 in fifth gear. (80mph) IN the city, should I drive nice, I average about 22-25 mpg.
From what I've read and seen, the car can go about 50-60 miles on the light. I'm not that daring though.
crzycav86
Car: 93 Nissan 240SX KAT
Usually, all you have to do accelerate slower.
Oh... and I shift at 2500 rpm...
Thrwnsprkz
Car: 240sx
lol... i dunno exactly what i getmy fuel gauge is broken, but when it worked i avg'd out that i was getting about 250 mp/tank... maybe that the gauge is just a warning before you get too low? I never saw a gas light in my life in my S14... lol
also calculated my highway mileage last time i went on a road trip and was getting 30mph highway at like 75-80 mph (calculated with a 17 gal tank tho)
and im a short shifter, never above 3k unless im really running her...
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
i usually fill up every 260 or so miles for 11-13 gallons. So it bounces around 20 or so mpg but I'm not exactly easy on her either. When I went to Arizona and back to get my new dash, I averaged 80-100mph the whole trip and was getting 350 miles a tank. Not bad considering the #1 spark plug isn't seated right, and the spark plug wire is split but electric taped together(she misses slightly). With a tune-up and a light foot, I could probably boost my mileage greatly.
But why would I do that?
sdtouge
Car: 1990 240sx coupe
your crazy will! going 100 likes it nothing.
that car does it well though.
VitaminT
Car: 93 240sx SE
My SR is getting about 26mpg. That was mostly hwy with just a tad of boost here and there.
Most of the time it gets about 14psi and 14mpg.
