Help!! my s14 eats batteries
StPeteS14
Im having difficulty diagnosing a problem with my S14. When i park the car/overnite the battery keeps going dead, no i did'nt leave any thing on, has any one else had similar problems? im sure you guys know more about sr's and 240's than me so any suggestions would be helpful
slidestyle69
Car: 92 s13
i would love to help you sir but you didnt introduce yourself before posting and my mom always told me to never talk to strangers
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
You either have a bad diode in your alternator, a accessory that stays on or some wiring problems. Has it always done this? If it just started have you changed anything since it started.
StPeteS14
The only thing i changes was a cracked battery connector, thats what i thought the problem was but when i fixed it... nothing, i looked for any thing left on couldn't find anything. Im daryl by the way.
StPeteS14
just remembered something, my head unit and oil pressure gauge have been freaking out. the cd player turns itself on and off and the gauge jumps wildly from 0 to 30 to 70
vin diesel
Car: 99 328i
take a look at your 12v going to you radio for memory.
StPeteS14
got around to testing for an electrical short today, i hooked up a volt meter in series with the battery and found 2 fuses that when removed each dropped the voltage from 12.6 to 11.4. Ive only seen tests done with a light not a volt meter so im not sure... do you guys think this could be the short?
Sil80315
Car: 1991 Nissan 240sx
sounds like its your radio has a dead end and causing the battery to drain.. It only takes about 8 hours to kill a battery pushing 12v's to no where
