fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Sat May 08, 2004 10:33 am
what do you mean by "passed the test?"
try shorting the starter and see how well it spins. just put the key in the ON position, take a screwdriver and connect the 2 leads on the starter solonoid (sp?) There are 2 bolts there that have wires under them, one goes to this plastic connector, and the other goes to the body of the starter. Just short those two together, you should get a small spark and the starter will pop out and whirr up. The sound should be a really strong sound, you should hear it really forcibly pop out and spin up. When I did mine I could hear it spin, but not really pop out (I know this because the guys at a local Advance Auto shorted a brand new one for me in their store to show me what it should sound like...)
If nothing happens, or the sound doent sound really strong, then 90% likely it's your starter. Brand new it costs about $150 with the core returned...
Another way to check if its your starter is to push start the car... if it starts that way then it is also definetly the starter..
let us know how it comes out!
