HELP my rb25 is stuck in a parking lot
DrIft Ready
Car: 1990 silvia built sr..
ive try everything..S14 with RB25 1 jen...was running great...4th time ever driving it drove it to lunch and came out and will not start. `1 i notised that the fuel pump was not on..so i hard wired it.2 the main power that u wire to the RB harness..the red with blue strip dose not have power? check eveything with vote meater..nothing..tryed hardwireing evething and still does not start..even tryed anuther CAS..have not tryed a new ecu yetHELP!!!!!!
Sandy sx
Car: 90 Nissan 240 sx
Wel.... If you're close by I'll come get it. Heh heh heh....
krayton
you tried all the basic stuff right?
im assuming so cause you started jumping right to hard wiring things.
id first guess maybe a fuse since it was running. loose wire... something
check your relays too
and im just gonna say it just incase, is the battery ok?
DeatschWerks
Just bc the battery reads OK under no load doesnt mean it is actually still good. You can try jumpstarting it without the battery hooked up. Or get someone to get a multimeter and check the voltage on the battery as you try to crank it. Ive had a battery that was only slightly low that kept my RB from starting.
DrIft Ready
ive recharded the batterey ever time i leave i bring it...it is a brand new oddisey. ya using a multimeter to check everything..................think it minght be a relay but ......
Modified by DrIft Ready at 12:20 AM 6/21/2006
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Get a friend or two, push the car and when it gets moving, hop in and throw it in first with the clutch depressed, and turn the key and gas it at the same time, pop the clutch, and if you've got enough speed it'll turn over and start right up. Then you can get it home for further analysis.
Nameless EJ6
Car: What the **** do you think.
stop hard wiring stuff.. jeezus.
DrIft Ready
the starter work..daa..ive done over 30 swaps...so dont be stuped~~~help me get this thing running..fuel works just fine
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
DrIft Ready wrote:the starter work..daa..ive done over 30 swaps...so dont be stuped~~~
hahahahaha irony cracks me up. I think this one might end up in my sig
check your relays near the ecu
Joe
DrIft Ready wrote:the starter work..daa..ive done over 30 swaps...so dont be stuped~~~help me get this thing running..fuel works just fine
wow...
M.O.B
Car: 91 240sx w/R33 Rb25det SII
LOL if that ish is still there tonight spence Im triple ai'ing that thing to my house jk jk (maybe)
Bluefire
Are you getting any spark? Fuel in the cylinders?
-Bluefire
DrIft Ready
OK i found what was wrong............the ECU blew...pluged in a nuther one and it worked but started somking so pulled it of befor that one blew..here is a pix of the ecu and where it blew.....any help on what wire is F#$%ed
DrIft Ready
the pin that fryed is #45 Ignition switch whats voteage is it saposted to be ..........................
and i briged the wire after the burned part and the ECU CAME ON.....BUT the wire got supper hot ..whats the deal
please help
Modified by DrIft Ready at 11:42 AM 6/30/2006
DrIft Ready
please HELP!!
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
need to put back all the wiring to it's direct points that u had before. Probably had nothing wrong. Check the ignition circuit by turning the key off and probing the ign relay. The relay has only one gate soo u will have 2 spots that have constant 12vdc and then the 3 will have it when the ign switch goes to the on position and the gate will close.
start with that and check all the red stripe/black body wires. After that u should find that your recieving 12vdc from the battery to a ground that is making the wiring really really hot and surprising u haven't had a damn fire yet! be carefull and get a professional to help u shoot all the damn 12vdc ignition circuit!
U CAN CATCH FIRE AT ANY POINT NOW! not a good thing
DrIft Ready
the thing is everything worked fine for 4 day..went to lunch and came out and didnt start...i think that the black with red strip wire is groung out on something......like that...going to check the harness over and see what going on..ps i did put everything back befor i tryed briging the wire..as soon a i new the ecu was the problem i but everythin back..pps what the Amp's on the wire
USMCgetsome
something changed. New gauge or loose faulty connection. Your taking the right action. I would start with the ignition source. Ign relay, turbo timer, and ignition fuse. You'll find a ground somewhere on that line. Should only see 12vdc.
