Komatsu Xhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=d8d2ddf669f460b5fdbec47e8bbc78b5HELP: MY RB20DET IS MAKING A WEARD SOUNDFri Sep 01, 2006 2:10 pm
Postby
Komatsu X »
https://forums.nicoclub.com/komatsu-x-u40814.htmlFri Sep 01, 2006 2:10 pm
HEY WHEN I START MY RB20DET IT MAKES A WEARD SOUND FROM THE STARTER OR FLYWHEEL.I JUST INSTALLED OS CLUCH KIT WITH LIGHT FLYWHEEL...HERE A 3 SEC SOUND CLIP
Postby
Shocker »
https://forums.nicoclub.com/shocker-u18595.htmlSat Sep 02, 2006 5:15 am
remove the starter and peek inside the bell housing inspecting the flywheel teeth and also examine the starter gears, make sure everything is messing correctly.
Does it sound like grinding? or like it could be normal? I have a twin plate and it doesnt do that. It sounds like the starter might not be on right and "meshing" correctly like others mentioned.
