TrendsetterAuto »
https://forums.nicoclub.com/trendsetterauto-u186198.html
Sat Aug 20, 2011 11:05 am
Hello, I am fairly new to this forum and have been using your info a lot the last year or two since I caught this Q-45 disease. I could really use some help here, my 1990 Q has some transmission trouble.
It is a bit of a long story to lay out all the symptoms and back history, but a long story short is I limped the original trans along until one day it wouldn't shift down at all. I bought another transmission and controller from a running driving car that was hit in the side and swapped it out a few weeks ago. And what do you know I still have the same problem! only now it doesn't throw the transmission malfunction on the dipslay. I have also noticed that I don't have any reverse lights. The car starts when in park and neutral as it should. It has forward reverse and park where they should be on the selector, linkage seems to be adjusted ok. But it seems to only have high gear, it wont shift down at all, not even with 1st or second selected on the shifter. this is the same problem I had prior to swapping the transmission. I thought maybe it was the controller so I swapped that with no change, I've checked fuses and switches in shifter, could it be a ground problem or something stupidly simple like that? It almost seems like the transmission is getting no power at all except the neutral saftey switch works and allows it to start. I also would like to have a look over some wiring diagrams for the 1990 Q-45 if anyone knows where to find them? this car wasn't available in canada until 1994 so my dealer here is of very little help.
Any ideas would be helpfull
thanks
