Help my pulley Leaks!!!
Oni-me-kyo696
Car: Nissan 240sx 91
I have a KA24DE that was crashed when racing on a closed off road. I understeered while hitting a road full of sand and went into a pole. My pulley was bent in at the the most for part of it about 2mm so I dicided to replace it. I couldn't find a normal size pulley so I got an under drive one and installed it. it fit perfectely (so I thought until I ran it) the thing was leaking alot of oil. I torqued it as much as I thought be safe and it still leaks. could I have broken the crank seal when I pulled the old one out? what do I do I'm pissed and lost
my91silvia
Car: 91 240 sx going to Silvia
Check your crank seal, cheap fix if it's the problem and it sounds like it is
navysnail
yup, i would bet its the crank seal.
