Klits562 »
https://forums.nicoclub.com/klits562-u133972.html
Mon Apr 05, 2010 3:30 pm
What year is your car?If its a 95 zenki then its most likely the switch itself. A friend of mine had the same problem, the motors still worked but the switch was fried, it turns out the 95 had a problem the switch sticking in the down position once the windows were all the way down and it would burn them out.You can try hooking ip a 12v battery to the motors using some wire and see if they work.
