DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Feb 20, 2005 12:31 am
Pure toluene should burn clean--depends on the purity of the batch. I've only played with it a little for the "whee" factor, even if it may have been all in my head. The engine was not designed for 91 after all. 5 gallons total in 50k miles is nothing. I'd worry if I used it often. I've read it's safe to use in mixes up to 30%, but of course, not everything on the internet is true.
The rxp stuff says it'll help HC and CO, which usually form together in localized rich pockets. It might do wonders for some things, but I doubt it'll help NOx readings.
