Help My Low Beams Turn on With My high beams but won't work when i try to use only the low beams
HillSideQ45
Car: Model: 1995 Infiniti Q45 Base
Engine: 4.5 L V8 278 hp
Dimensions: 200″ L x 72″ W x 56″ H
MPG: Up to 17 city / 22 highway
On My 1995 Infiniti Q45 My Low Beams Turn on With My high beams but won't work when i try to use only the low beams What could it be also the car sat for a month and a rat or field mouse got in the engine bay and ate my hood insulator not sure if it chewed anything else but if it's a wire problem please let me know thanks I don't wanna blind anymore people with my high beams
EdBwoy
Hello, welcome to NICOclub.
I was going to suggest you check your switch on the steering column, but the mouse chewing throws me off balance there. You might be best positioned to get in there and start probing things.
Do your fog lights still come on as expected?
To help you on your journey, i'd look up the electrical schematics of the car, the lighting section especially in the factory service manual. The link is in my signature below.
macgiver
mac , I believe 95 Q's have a similar headlamp relay , boxed and usually firewall mtd. & towards drvr's side ,is whereas in my J30 .Now it's a strange animal ,because inside it's comprised of 4 or even 6 separate relays where each Low beam ( R & L) and each Hi beam (R & L) are individually swiched and including "the grouping" of Hi with the Lo . And theres so many wires connecting that rat may broken , in addition to the notoriously faulty "Relay-Box" . First locate it & check wiring for damage ,then tap the "Box" and see if you trigger an intermittant turn-on action? Many simply need replacing . :yesnod
Sometimes unplugging electrical conn.'s and applying quality el. cleaner/lube/protectant combo such as "De-Oxit"on male & female pins , then insert / de-insert several times kinda "cleans & sets a better connection. Be carefull if you buy like the CRC brand "Electrical Contact Cleaners" , most are really super pure "Brakleen", w/no lube nor any "protectant" qualities for longevity - terminals can / will corrode in salty winter climates ; also that concentrated form must be "tested on a non critical spot" , check for melting of plastic/rubber. :dblthumb: Glen
11/19/2017
HillSideQ45
Thanks For The Answers I will be sure to follow the head light wires to see if anything is broke or maybe just us My multi meter my fogs don't work my blinkers do though and also reverse and stop lights are all workin
