No... eventually it will lock up.....Jesda wrote:Checked all fuses I assume, including fuel pump fuse?
The J30 is an interference engine, so I assume it wouldnt just keep cranking if the timing belt snapped like on a non-int motor...?
OKAYI DO THAT WHEN I GET BACK TO THE HOUSE ILL BRING NEW UPDATES ON IT TOMARROW THANKS FOR ALL YOUR HELPJesda wrote:Checked all fuses I assume, including fuel pump fuse?
I assume you mean it doesnt start and doesnt turn over? If so then the first thing I would check is the battery, then the cables going from the battery to starter, and last check the starter itself.tdavis1975 wrote:My infinity j30t starts but it doesn't turn over, what is it?
