absolutely yes. I had a almost the same problem and the switch was the culprit. worked fine on high beams, but one of my lights would just not work periodically.jak89 wrote:Ithink the ground is alright although i dont have a meter to check it. If the switch was going bad could it cause only one light and the high beams not to work?
