Help my grinding steering wheel
Tex
My steering wheel makes a dry grinding noise when I turn it. Sounds similar to a dry bearing. I assume there is a bearing in the column somewhere. Could this be the problem, and can it be replaced with ease?
NISTECH
following these guide lines would help us help you a great deal tex. http://www.nissaninfiniticlub....41781
Tex
Umm, it's a 1992 Nissan 240SX? I guess I'm not sure what you think I'm leaving out.
NISTECH
well that was an important part there ,what kind of car you had. does it have tilt as well. air bags? have you added an after market steering wheel or is thae hole coloum still stock?
Tex
Straight stock car, no mods anywhere. Column tilts. No airbag, my car is a 1992, airbags weren't common in cars until a year or two later.
The grinding noise occurs whenever you turn the wheel through the duration of the rotation, meaning it doesn't just intermittently make noise. Sounds like dry metal scraping, and is very audible.
NISTECH
pull off the coloum covers behind the steering wheel and see if it still does it.The cover has 4 to 6 screws holding them on from the bottom side. you do have a bushing at the top of the coloum but they dont typically go bad. once you have those covers off you can pretty much see the bulk of the coloum. have you been able to isloate the noise to the top or the bottom of the coloum at all?
