The CA doesn't have a cap, or a rotor, or plug wires, or one coil either. It's a direct ignition setup up. It uses a Crank Angle Sensor to determine the timing of the motor and then sends a signal to each of the 4 coils that sit directly on top of the spark plugs. Pretty cool, huh?2BN_S13 wrote:Maybe you need to replace your distributor cap & rotor.
I worked on a mazda last night that had a "shaking stutter" and the rotor had just all of a sudden shed a large piece of metal right off it's striking surface.
The plugs got pretty fouled up too because the fuel was not ignitingcompletely. And all the plugs wouldnt be black if it was just one chamber either...
More than likely your #3 coilpack is leaking spark. But if your plugs are fouled, you're bound to get the same effect as well. I encourage you like I encourage all, check your wiring to your AFM and also change your water temperature sensor as it could be slightly out of range causing a rich condition. Also check for leaks. If your system is rigged (notice I didn't say ghetto), would be a good time to go over all the temporary patch-work. Hope this helps a bit...............datsunboy wrote:all the way through the rev range!It was perfectly fine one day......then a few days later when I drove it next.....that started happening!have no idea why.I have 440cc injectors and a standard ECU.....so it is running rich.but it ran fine for a few days before that?cleaned all the plugs ( black as hell )....started it up....and it ran fine untill I gave it a rev.....then back to the same problem
Is this problem likely to be:boost/vacumn leak?screwed plugs ( even tho they are pretty much brand new....about 30km's on them )maybe a stuffed coil pack?
I tired unpluging all the coils one by one......and they all made a change in the running of the motor....but number 3 didn't make as much change?( the plugs were more than likely black again when I tested this.....so could be part of it )
anything else it could be?****ty earth somewhere?low voltage to something?any sensors cause this if they were dead?
I'm getting a UV eraser in a couple of days.....so I will be able to re-write my ECU to suit the injectors, and stop it from running rich.
cheers for any help guys.
Did you retrieve the codes off the computer? I would personally purchase a new water temperature sensor. But please let the computer attempt to tell you where the car's problem is at.datsunboy wrote:ok.....managed to bleed the brakes up and take it for a drive 2night.....it's boosting to 5psi now ( I forgot they shouldn't boost much when they arent in gear! ).
It's still pissing around....much slower than the first time I drove it!
I chucked the boost gauge on the other side of the cooler, to see if it was leaking anywhere......but could only hook it to the turbo itself......gave it a quick rev, and it managed to pull 16psi not in gear ( before I let go.....wasn't excpecting it to go that high )
so that means that it's main problem is when it is under load.
any further suggestions?....could it still be worth buying a new water temp sensor?.....is it likely to be that?
It's not dumb man, you just need clarification. The single wire thinga-majiggy is called a water temperature sensor and of course the square pulg with two wires in it is called the water temperature sensor.iliketocrash wrote:My car kind of has the same problem but i was wondering about the water temp sensor. I know this is real dumb... but are there two different ones? cause my last car had one for the ecu and one that just ran the temp gauge in my dash cluster.
Very interesting, I'm not the only one to have had this happen then.datsunboy wrote:spark plug #1 had a crack in the porcelin ( at the top.....not the sparking end ).
