Help My clutch!!!!!
WorkinDriver
Car: 240's
Hey I need some help please. I have a 91 S-13 SE. I hit a box on the freeway at about 95 mph. It cut my clutch line. I then rigged it and got it home. However, doing so burned the clutch, killed the master cyl ( due to motor oil ), and the box took care of the slave cyl. So I had all replaced. But, now when its cold, the clutch work alright for a while, then the pedal get firm, and then it slips. When the air temp is hot, the pedal is already firm ( no free play ) and it slips so bad that it wont stall when i put in first gear. I thought air bubble. I bleed the line, no bubble. The fluid level is fine. not max. right in the middle. When the pedal is firm I let some fluid out the bleeder screw, and its fine for a while. It seems like the fluid is being blocked from going back into the master cyl.Im stumped...what do you guys think? Any help is always appreciated. Thanks.
Importroller
Car: G35 and 07 Altima 3.5 6spd
i dont even know where to start. maybe try using all new brake fluid in the cylinder. check to see if you have any leaks anywhere
WorkinDriver
Car: 240's
Done that Still tripsI even tried using dot 3 synthetic
WorkinDriver
Car: 240's
because its thiner
ricebike
2002 Quest
2005 Altima
check clutch pedal free play?
WorkinDriver
Car: 240's
yea...Movement before the pedal engages
WorkinDriver
Car: 240's
Do you have any ideas ?
ricebike
2002 Quest
2005 Altima
still hooked into that clutch damper box on the chassis? i heard that some of them are air traps.. but since u bled the system, this may not be your problem.
It was a biaatch to bleed mines when my master and slave cyl changes... i had aftermarket raybestos on both...it failed me after a year... part replacement were free, labor wasn't. maybe you also have a defective part; it can happen.
i'm gonna replace the hose and bypass that clutch damper next time i do a clutch job... mine's isn't broken down yet soo i'm not gonna fiddle w/ it.
i just have a lifetime warranty clutch hose from napa sittin in my garage for the next failure to happen.
good luck w/ tracking it down. hopefully it's not an internal problem w/ the clutch fork/throwout bearin.
WorkinDriver
Car: 240's
Thanks for the info...What does the damper do...why put it there if its not needed?
