p00t »
https://forums.nicoclub.com/p00t-u5026.html
Sat Jul 26, 2003 7:37 pm
the engineering forum is for more technical/design discussions. next time just post it in the online nissan mechanic forum.
sounds like your clutch isnt disengaging. do a full check of the slave cylinder, and lines. try bleeding it to make sure there arent giant air pockets in your clutchline. my bet is its something with the slave cylinder.
if that checks out fine, and you are sure the entire master cylinder, lines, and slave cylinder are functioning properly, the clutch release mechanism may have come undone. you will need to disconnect the transmission and inspect the throwout bearing and withdrawl lever setup.
