Help! My car loses 10 kw with new intake on.
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
Hey Guys, took my car into get major service/dyno'd today and to get my new Fujita intake installed. They said on the dyno with the new intake on, the car lost 10 kw than with the stock intake on, and that it was running too lean. They said I'd need to get a new ECU chip which would cost around $1700.
Any ideas? Why would this be happening?
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
How long was the intake on the car?
Lean means too much air. So the intake is working, maybe you just need to wait for the ECU to learn to add more fuel.
Jeff
Andy_V35Sky_350GT
Well, I didnt install it, I got them to. I was concerned that they may not have reset the ECU (i always thought you had to unplug the battery after installing parts) or that they had f'd up the MAF.
Andy_V35Sky_350GT
Well it dyno'd at 167KW (around 225 HP). Not what I was expecting, thought stock's at least hit 230 HP, and this was with the stock intake, so with the F5, it was 10 KW less.
Also, they put in 5W-40 instead of the regular 10W-30. It Summer here, you think it'll be ok?
gwoods
I don't know man I'm not a big fan of dyno's.
My last car was a 5050lb 4 door Hemi Ram. When I had it dynoed it was running 14.5's at 95/96 mph. The dyno said I made 269 RWHP. There is no way a 5050 lb vehicle can run a 14.5 with only 269 RWHP. I had about $4,000 in go fast mods. It was a club dyno day and a stock Hemi put down 255 rwhp? The stock Hemi said he was running 15.5's. There is no way 14 hp would make me a full second faster.
I don't gauge performance off dyno's. I would use a dyno for tuning if you had a turbo or supercharger.
Take it to the track and run it with and without the Fujita. I bet your faster with it and that is what matters!
Jeff
gday
Hot air intake FTL.
gwoods
gday wrote:Hot air intake FTL.
Okay now you don't know what your talking about. The 2007 G35s have two sets of plastic tubing that bring air from in front of the grill and below the front bummer to the fujita intake.
gday
Yes, but the Fujita are an open filter intake... Not enclosed in a heat shield like the OEM intake... So it's a hot air intake.. Especially when the hood is closed.
There may be some circulation but it's mostly HOT AIR...
The 2 vents for the OEM intakes works fine because it's enclosed. Which is why the OEM intake is already a cold air intake. All you have to do is replace the restrictive OEM filter with a high flow filter.
Hot air intakes don't make any sense.
gwoods
Opinons are like bungholes
04G356MT
Car: 04 G35 6MT
^^ everyone has one... and they all stink...
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
joe603
Car: 2014 Durango R/T
So you really think that the factory filter housing keeps the air going into the engine any cooler than an aftermarket, open element design? I would think that the OEM enclosure would trap heat and raise the temp...maybe even more.
The open element filter design will benefit more when the car is moving, as fresh air will be circulated.
04G356MT
Car: 04 G35 6MT
IMO ignore the dyno, take it out for a spin, see if you feel a difference, i know i did
Andy_V35Sky_350GT
So, can I get some educated opinions, is it ok if I stick the intake on for a week for general daily driving if its running lean?
Is running lean really a bad thing? Will the ECU correct this issue? Will re-setting the ECU (unplugging the negative battery terminal) allow the ECU to adapt to the new intake?
I knew the dyno would be lower then what the car actually outputs, considering its the middle of summer here (ambient temp was 30c in the workshop) and the car obviously gets alot less air on a dyno.
So, is it ok to run lean or will it mess with my engine?
04G356MT
Car: 04 G35 6MT
drive it, your ECU will self tune itself a bit and add fuel, and lean isnt bad as long as your not too lean. lean is actually good to a extent
Andy_V35Sky_350GT
Well, its Summer here, and avg temps are around 30-32 c in the day.
I will probably just re-install it, reset the ECU and see what happens.
gday
wtf are you people talking about? the OEM enclosed intake don't trap heat. haha
It's enclosed in plastic... If anything, your shiny aluminum piping trap more heat. Touch the OEM plastic after running your car.. It cool to the touch.. Now touch your shiny aluminum intake.. Warm to the touch.
The oem intake takes in cooler air then any short ram intake period.
Which is why Comptech made an aftermarket intake simular to most OEM intake. Called the Comptech Ice Box.
Notice how it's enclosed. You won't see a open-end shortram intake such as the "fujita" intake named ICE or Cold... For a reason. It takes in hot/warm air.
All the short ram does it some kid of noise when you push it. That can cause a placebo effect and make your Butt Dyno feels "Fast".
04G356MT
Car: 04 G35 6MT
who is this troll....
gwoods
04G356MT wrote:who is this troll....
I don't know but you can't argue with an idiot. They will drag you down to their level and beat you with experience.
I'm just going to ignore him and hope he goes away. He doesn't know what hes talking about but your never going to change his mind.
Jeff
zozoka1212
Car: 08 Infiniti G35x
joe603
I agree with the arguing thing....I like this analogy:
Arguing with someone on the Internet is like winning the special Olympics...even if you win your still retarded!
zozoka1212
LMAO
Can't argue. That is true.
zozo
Andy_V35Sky_350GT
Does anyone else here have the Fujita? Any issues? Anyone had it dyno'd?
zozoka1212
When they dynod your car. Did they put a fan the front of your car? You have the intake but that needs air if they did not put a nice big fan to blow air to your intake that would be why.
zozo
