richierossi90 wrote: car drives fine i but sometimes when i am sitting there the idel goes up and down and my vacume is any where from 20 19 18 17 is normally around 18 17 ideling and then out of the blue it will dope to like 13 or so and my rpm will drop is this right what should my vacume be at and what should my car idel at sitting still does any one no what the problem is other then vacuume leak cuz i have it recirculated and changed all the vac lines
oya its a redtop sr and i am running the aem true boost
my vacume is between 19 and 17 and it idels qt 1.5 to 2k on a cold moringand like 9 sitting still after its warm and then it jumps around sometimes sorry for this being so long
Can I get a translation to english?
I had the same problem... thought it was a vacuum leak, turns out i f'ed up the settings on my SAFC. I would check to see if the AFC is tuned correctly...
