HELP, my car drives fine but ABS, VDC off, SLIP lights are on!
2006g35coupe_owner
Car: Infiniti G35 Coupe
I searched the db but couldn't find anything. Anyway, I have a '06 G35 coupe. Recently, my ABS, VDC off, and SLIP lights would come on unexpectly (happened while my speed is at 120 Km/hr, 110 Km/hr, and 80 Km/hr). After ~2 minutes, my speedometer would drop down to zero; the car can still be driven but there is no speed feedback so I will then have no idea how fast I'm driving. Please help!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Aren't you in warranty? Or is the car hot?
silkysmoothyjud
Car: 1994 Q45
please check your alternator belts and/or alternator
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
maxnix wrote:Aren't you in warranty? Or is the car hot?
hahahaha hmmmm maybe maybe
if the speed sensor is bad will it trip off all those lights? in older Nissans it would kill the speedo but with newer cars wouldnt it mess up the new traction control systems?
take it to infiniti thats the easiest solution car should be under warranty unless you've driven it 24/7@80mph since you bought it
silkysmoothyjud
Car: 1994 Q45
A freakin 06' with a problem? Dam, they are not making them like they used to....
