HELP. My baby is Bleeding. Power Steering.
Duce40sx
Well, yesterday I noticed droplets of power steering fluid on my driveway.
I can see that it is comming from the Banjo fitting area as well as from the rubber line that goes to the rack.
So, I will upgrade to Stainless Steel Power Steering line.
NOW WHAT IS THE PART NUMBER FOR THE WASHERS on the banjo fitting?Can I get these at autozone?
574-240sx
Car: Nissans, Toyotas, Subaru
They are just copper crush washers. You can probably pick them up from the dealer for cheap or go to a hardware store and see if you can find something that will work.
Duce40sx
Yep, thought so.
THanks~
