Help my 94 Q not running smooth when warmed up/Hot day.
svtgtr
Hi. I own a 94 q45 and in the mornings when start it up its fine and runs nice. but when the car warms up i can feel the car shake and loose power. Basically when car is cold, it runs fine and fast. when car warms up/ hot day, the car jsut boggles out and feels liek its running on a 4 cylinder.
I also noticed when its cold, the gas peddle is much stiffer but when car warms up or a hot day... the gas peddle is soft and no matter how much gas i throw in, its slow as hell.
Anyone know the cause of this? Is this a common problem? I know im not giving much info. This ive done is do frequent oil changes, fuel filter changed
THanks Andrew.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
This is covered in the FSM, So please read it.
Here is the section that is more about your problem: http://www.nicoclub.com/FSM/Q45/1994_Q45/ec.pdf
Here is the FSM for your car: http://www.nicoclub.com/FSM/Q45/1994_Q45/
Or if you have a copy even better.
svtgtr
ppastos wrote:This is covered in the FSM, So please read it.
well thanks but im not sure what im looking here
Edit: is this a common problem that Q's have?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No, of course not. "Hot" in Ontario in November makes one wonder.
Go post in IOM and detail all the recent maintenance, the engine's condition, type of fuel, etc. Include transmission, intake, fuel system, and coolant maintenance data.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Welcome to NICO!
First thing I would do is check your MAF. Have you checked your fuel pump? Do you have a buzzing sound coming from the back seat of the car?
Those are the first 2 things id check, check the fuel pump first
svtgtr
He thanks for the welcome! Im not sur what a MAF is but as for the fuel pump. I do hear a buzzing sound from the back when i turn my key but i thought that is like normal. If there a way to check the fuel pump yourself instead of bringing it to the infiniti dealer?
THanks for all the help.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Sure, read the threads about how to T it off after the filter and check the pressure at idle and WOT.
For the more elctronically sophisticated, Q45tech has mentioned observing the wave forms on a scope to see a bad armature.
elwesso
2007 BMW M Coupe
svtgtr wrote:He thanks for the welcome! Im not sur what a MAF is but as for the fuel pump. I do hear a buzzing sound from the back when i turn my key but i thought that is like normal. If there a way to check the fuel pump yourself instead of bringing it to the infiniti dealer?
Yeah check your pressure. Q45.org is a great place to start for this stuff
