pro_leonk »
https://forums.nicoclub.com/pro-leonk-u30277.html
Sun Jul 03, 2005 3:09 pm
Hi guys,
I recently bought a 8/89 Nissan 240sx with 160k on engine and transmission, all stock. The time I bought it, the owner told me that the fuel injectors were leaking badly. I thought no big problem, get new O-rings and new rubber gormets and that should be fine. (Note: the car was in a not very well maintained condition, was low on oil, no clutch fluid and low power steering fluid)
I bought it, drove around in town, and sometimes stalled on me because of the exessive fuel the engine got (e.g. driving from 50mph then stopping at a red light) 5secs later, it started up fine again.
On the way home, it stalled on me three times. The frist time, it started up with in a minute. The next half mile i had to always stay on the gas, otherwise t he rpms would have dropped to far and it would have stalled. Waiting at the light, I could smell the fuel not being burnt properly, hence, there was a lot of white smoking coming from the exhaust.I drive on mile, it stall again... but this time i can see some slight smoke coming from the hood. i jump out, and smell some electrical stuff burning up. I poured some water near the injectors ( i was afraid that the leaking fuel would catch on fire, or thought that was the problem)I pull over, engine cranks but doesnt fire up. After waiting for 20mins, it finally starts again. Pulled over to a gas station and got some gas (91oct, dont know what the previous owner used) and poured in a quart of chevron 10w-30 oil. Engine starts up again, no problem.
i drive for another 5 miles, it stalls again. Heard some ticking noise when i pressed more on the gas while driving in 4th between 2500-3000rpm.Last time it stalls again, doesnt start up, only cranks...had to tow the last few miles home.
At home, i replaced the fuel injector rubber gormets... no more leaking!Now, when i try to crank it, it just turns over. I replaced the spark plugs and the spark plug wires (were cracked)
I am still confused, why it doesnt want to start up anymore. I found out that the fuel injectors are not firing at all, so i dont have fuel. I get fuel till the fuel injectors. I guess they dont get a signal to fire... the cables are in fairly bad condition, but should be able to send a signal through.
The check engine light is on as well... i pulled the codes, and i got a code 55 - which means no malfuntion. I guess that doesnt help me further.
I hope that there is something that i am missing out or not realizing... but i hope you guys know more then me. Any help, hints or further troubleshooting is greately appreciated!thanks in advance!
