deevietboi »
https://forums.nicoclub.com/deevietboi-u52224.html
Fri Jun 26, 2009 1:34 am
hey guys i have a question, my car is leaking radiator fluid right now. I noticed my car was starting to heat up a little so a pulled over to check under the car and hood, and saw that i was leaking fluid around my water pump
filled her back up with 50/50 and temp went down
it seems to only leak when i turn the A/C on, other wise everything is fine
can this be a dead water pump?? or can there be more to it?
why does it leak when i turn the A/C on....
engine is a sohc KA with 190k miles
