bruinbear714 »
https://forums.nicoclub.com/bruinbear714-u1106.html
Sun Sep 29, 2002 2:16 pm
Well, first of all I would remove the intake tubes, radiator shroud, fan, drive belts, power steering pump, water pump, and everything else in the way to take off your timing cover.
Once your timing cover is off, you can pop out the timing tensioner and you can pull off your chain easily. As for removing the sprocket, use an impact gun. Or if you don't have an impact gun, put your car in fifth gear and give that nut a tug while the timing chain is on.
Anyhoo, the bottom line is you will need to remove EVERYTHING in the front of the engine, the manifolds, and the timing cover, chain, tensioner, and oil pump to replace your head gasket. Its not an easy task. Also make sure you get the head gasket kit that contains all the gaskets, especially the oil seals.
