I would remove all the emissions but ever since nico changed it's layout the thread that explains the removal doesn't show the pictures no more. So i don't want to end up messing up the lines, but if some can walk me through it I'll greatly appreciate it!costa_rican13 wrote:why dont you remove all your emssions? you would then only have 2 vacuum lines on youre intake piping. and you can say byebye to all those little lines you dont have. and you will less vacuum leaks too as well.
72* and you can't remove your emissions anyway so your post is pointless. it doesn't matter if it is warm there.... I will take my cold weather and lack of nazi state government. I am actually just jelous of the nice weathercharat wrote:im so glad i live in cali... it was like 72 degrees the other day.
we're in the process of fixing tech articles... go to this thread and request to have the pictures restored and ye shall have themS13_RB25 wrote:I would remove all the emissions but ever since nico changed it's layout the thread that explains the removal doesn't show the pictures no more. So i don't want to end up messing up the lines, but if some can walk me through it I'll greatly appreciate it!costa_rican13 wrote:why dont you remove all your emssions? you would then only have 2 vacuum lines on youre intake piping. and you can say byebye to all those little lines you dont have. and you will less vacuum leaks too as well.
If your close to Philly I can help you out if you still need it...And I can walk you thru the egr toocosta_rican13 wrote:no problem! now get that car running!
why remove emissions? if you say better HP/performance thenfiznowler wrote:72* and you can't remove your emissions anyway so your post is pointless. it doesn't matter if it is warm there.... I will take my cold weather and lack of nazi state government. I am actually just jelous of the nice weathercharat wrote:im so glad i live in cali... it was like 72 degrees the other day.
So let me make sure if I got this right. The line coming from the intake Mani to the canister can be just plugged up with a screw and one line coming towards the mani, from the canister, can be just looped back into the can?? But if I want to remove the can what do I do to the line going to the fuel tank?? Plug it up with a screw or what??driftneil wrote:You can loop the canister hoses onto eachother.....And eliminate that hose if you want. Or pull the can out, and block off the hoses going to it.
