DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Nov 08, 2004 5:50 pm
Is it valvetrain noise, or lower end knock? Knocking is most often a sign of lower end damage. Bad bearings/journals. Usually indicates past abuse, poor maintenance, etc. I would avoid any engine that had such problems, since the effects probably aren't limited to one area only. I.e., you could fix the knock, but have something else break down within a year. For $200 you could probably make some money if you part it out, or you could swap the engine to get it going.
