Help!!! more issues
Ca_laurier
so about a month ago i was driving home and my car started to bog out every once in a while. Later on i started to loose response and at this point the car won't even start anymore. It will try to crank over but soon after it will just die. I have changed all the IC couplers and clamps tried boosting the car but when it started it couldn't hold an idle and shortly after boged out and died.
fuel pump is working. i installed a walboro 255lph but i didn't upgrade the frp. could this be one issue??
to my understanding its almost like the car isn't getting spark
any help would be much appreciated
ilovecoupes
check timing
check coilpacks maybe new spark plugsmake sure the ground to your coilpacks is good
Ca_laurier
Just ripped out the coil p0acks and checked them and they are all good. i am just off to pick up some new spark plugs and drop those in
