dkyuss »
https://forums.nicoclub.com/dkyuss-u69182.html
Mon Jun 25, 2007 7:48 pm
So the story goes.... I have a 91 Maxima SE with 290,000K.
Water pump began making noises last week before completely failing on the way to work. I limped her home and began the repair in my driveway.
I picked up the 50$ pump and timing belt (seeing I'm there already) and 12 hours of crawling around skinning knuckles, I finally have the waterpump off.
Now the problem is that there were 6 blades on this impeller. There are now ZERO, as all have broken off. ONLY FOUR PIECES have shown themselves! This means that 2 chunks of steel (approx 1/2" x 1/2" 'L' shaped pieces) are floating around my coolant system. I have fished with wire and poured water through every coolant hose and port I can find and the pieces are still missing.
I cant imagine that the pieces will circulate throughout the coolant system, so I shouldn't have to worry about the pieces jamming and wrecking the new water pump.
My question is;Where might these pieces collect? Could they get to the Radiator?Will it harm the engine if I just put er back together and run it?Any help thoughts or suggestions greatly appreciated!
