help!miss up thread on s13sr20det block what to do?
chetos13
Car: 1991 240sx
the bolt screw in but i doesnt tightin up. tried a tap a die but still the same. would a rethread kit work event though the hole will get bigger help if u know what to do or this happen 2 u before. thanks
meangreens14
Car: s14 red top sr PARTING OUT!!!
daily:2008 subaru impreza wagon(knightrider)
Umm...I know your probably in a hurry for an answer, but with your explaination its hard to tell what your asking of us? In detail, what happened? I have backed out some broken studs before as well as performed hand taping / rethreading. Please do explain so we can help you.
chetos13
Car: 1991 240sx
thanks i built this car with my friend. we the did the swap. and i did the bodykit and the whale tail along with the paint. i dont think u can say the the car is really urs if u didnt do all the work yourself. so that way u know every inch of your car.about the problem i was trying to put the bolt back in the block. its the bottom line and i guess i didnt put bolt it in straight and when i was screwing it back in but the bolt wouldnt get tight. it screws goes in but doesnt tighten up so oil squirts out. it has the stock turbo and lines.
chetos13
Car: 1991 240sx
any one please help me with this problem? help ur fellow 240 member
tonynalli
You wil need to clean out the hole and retap it, then put a helicoil in
chetos13
Car: 1991 240sx
thanks man. have u done this before. would i have to drop the engine or can i do it while its still in the car.
