Help meeee what should I do???
Justin35ll
Car: s13 coupe sr20det
Well I got the 10mm allen socket I needed today to pull my head off so I did it (with a 3/8ths drive it sucked)
But I got it off and took a look at the "water" I saw ontop of piston 3 and 4. Well I think it wasn't just water looked like some kind of fungus was living there LOL. I cleaned them out though and it looks better now, but idk what to do. I'm scared the rings are gonna be bad.
I couldn't do a compression test or a leakdown test to test the cylinders.
I don't know if I should just replace the gasket seal it up and hope for the best or spend a lot more money and time to do a full rebuild.
Also another question. Are the head bolts TTY bolts? Do I need to replace them?
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
How do the cylinder walls look?
Noobishguy231
Car: Saturn Death-cab. (Nissan 240SX aspirant)
while i'm all for things growing, I dont like them growing in engines. Ew.
Justin35ll
Lol yeah it was pretty nasty. The walls look like they're in good shape.
burntricer
Car: 90 S13 SR20DET Redtop
was the engine sitting outside? like was there water in the spark plug holes when you pulled the plugs?
i would check the cyl walls..
Justin35ll
It was probably sitting outside in japan. The place I got it from took it out of the big *** trailor thing and put it on the shelf. Then I bought it a few days later.I'm pretty sure there was no water in the spark plug holes.I took the plugs out and looked inside 3 and 4 and could see a reflection of the light so I was like wtf. Then I shook it and could see it was liquid
boro drift
I'd clean and lube the cylinder walls and run it. Have you drained the oil or pulled the plug in the oil pan? Make sure there is no more water hiding in the crank case.
Justin35ll
Alright glad you agree. I was afraid all I would hear is do a full rebuild.
But yeah I def will be draining the oil. I havn't yet because it's sitting on the ground, but I could pick up the short block with a friend now and set it on something to drain it.
Is it possible to take off the front cover to readjust the timing chain? My discolored links don't line up with the makrs on the cam gears, and prob not the crank either.
boro drift
Justin35ll wrote:Is it possible to take off the front cover to readjust the timing chain? My discolored links don't line up with the makrs on the cam gears, and prob not the crank either.
NO DON'T DO THAT! lol. It doesn't matter if the links don't line up. As long as the the crank pully is at tdc and the marks on the cam gears are in the right spots, your golden.
Justin35ll
Alright I'll leave it alone then lol. grr I hope this thing works.Will it be okay to reuse the head bolts? I checked the threads and there was no sign of damaged threads and they didn't look stretched not that I would really be able to tell anyway though
boro drift
I don't believe the head bolts are tty. If they are not corroded, I would reuse them. Wire wheel the threads and under the bolt head.
Justin35ll
Alright I'll give it a shot then. What should I use to clean the deck/head surface from where the gasket was? I took all the thick stuff off with a razor blade, but should I use a scotch bright pad or somthing to get it cleaner? I don't want to put the deck out of specs or anything
boro drift
Use a red scotch brite and just take what ever is left by hand. Be very careful and take your time. Check or have the head's deck checked for warpage. It my need decked.
Justin35ll
Alright I'll check it with a straightedge tomorrow, thanks for the help
japslapsilvia
Car: 90 s-13
check the length of the head bolts, in the FSM it states that they can be re-used if they are not stretched too much. i wouldnt re-use them anyway replace them or use studs
since u have the motor all torn apart, you might as well hone the cylinder walls, and put in new rings, main bearings, and rod bearings, it would be dumb not to at this point.
Justin35ll
Yeah, it's hard not to. I don't know what I'm going to do yet. I just want this thing running right now, but after I get it running I'm gonna wanna start making more power, so it seems logical to take it step by step and just spend the extra 1000 bucks and build the block.. wish I had a job lol
