Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jan 16, 2004 7:43 pm
you'll need some hosing and a clamp to secure it. either in your hotpipe or the throttle intake pipe (after the a IC) you'll need to mount this. It'll require that you have a small extension off of the pipe that this mounts to. Weld a small piece of tubing to the pipe and fit the hosing around it, then slide the BOV into the hosing and clamp the ends down. The shorter the hosing, the better.
