help me!!!! with the rb25det (exhaust camshaft)
maickS13
What camshaft can hold? In rb25det, it exhaust, since this broke the original, which was the rb25de can be filled, but the rb20det or rb26dett fit?
en español: el leva de escape del rb25det que tengo se rompio, y quiero saber cual me sirve, yo se q puedo ocupar el leva del rb25de, pero nose, si se pueden los del rb20det o rb26dett, alguien sabe algo de eso
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
utilice un 25DET.
I believe the 25DE and DET camshafts are different. I do not know by how much. I will look up the part numbers tonight.
¿Cómo hizo la rotura original?
l0nestar
2004 Toyota Altezza
Mi Español no está bien.
maickS13
the cam is broken, as was tightening the bolts of the bracket, in order to tighten, but broke the same, which was not the reason, if you tighten the other the same. 25de the Cam, is the same, but has over 260 ° prolongation,
l0nestar
2004 Toyota Altezza
I see. you were tightening the camshafts like the service manual instructs you to, and the exhaust camshaft broke. (Another user "Darius" and I spoke about this before. The instruction manual is not very clear or just wrong.)
To verify - the 25 DE cam has the same lobe dimensions, but 260* duration?
maickS13
I have the manual, and follow to the letter the directions, but still broke, but the cam admission, no nothing bad happened. I often disarmed ca18det and I had never spent anything.
Shocker
Car: 89 240sxHB rb26/30
maickS13 wrote:the cam is broken, as was tightening the bolts of the bracket, in order to tighten, but broke the same, which was not the reason, if you tighten the other the same. 25de the Cam, is the same, but has over 260 ° prolongation,
Bolts to the bracket? You mean the cam caps? You tighten those a little bit at a time, starting at the center, and working your way outward equally in both ends. (this method is critical so that the shaft doesn't over bend which could result in breakage) The dowel on the cam should be at a 15 degree angle above the horizontal axis (this would be the earths surface as reference, assuming a CCW rotation)
Once you have the cam secured, you install the black cover piece, then the cam gear. Use the nut like part of the cam with a crescent wrench to hold and torque down the cam gear with a ratchet.
maickS13
if I did that, everything I did good and correct, as I followed the instructions, I knew long ago, in fact all the engines were tightened in the same way, just change the torque/tighten. was not my fault, no one could explain why I was broke, only material fatigue or poor manufacturing. I have many armed engines and I never had happened
pd: This post is aimed at anyone tell me which is similar exhaust cam to install in the rb25det
gawdzilla
Car: none
i'm pretty sure the 26 cams will fit, but it will make the car run like crap. better to just find the correct 25 cam.
maickS13
is that I can not find the cam here in Chile, are exhausted and only ebay that are for sale are HKS and are very expensive, but for the future maybe, but now I do not have enough money to buy.
here in Chile, a port of call iquique , where they only JDM cars and parts, but no cams for my engine, jajaja,
