ghx407 »
https://forums.nicoclub.com/ghx407-u51111.html
Sat May 05, 2007 6:28 am
Your FPR and boost gauge vacuum lines are fine. As for the rest of the stuff:
1. Oil feed/drain: What is that thick rubber hose going to your turbo's center section? If it's the oil drain, it has to be facing downwards. If it's the oil feed, I'm speechless.
2. Wastegate: Leave the top port open. The side port vacuum line should go to a fitting on the compressor side of the turbo. If you don't have one, tap one in.
3. MBC: I really suggest you don't run it for now. Let's see how the car does with the current wastegate spring.
4. S-Shaped Hose: One side of this hose, or any hose you use to replace it, goes to the tube where your BOV is currently sitting at. The other side of the hose goes to the idle control valve tube, which is next to the throttle body.
5. BOV: Remove it from it's current location (that's where the s-shaped hose goes). Weld a flange somewhere into the intercooler piping and install the BOV there. Run the BOV vacuum line to the brake booster's vacuum line.
Good luck and keep us posted.
