Help me with my problem please?
slowsky
Hey everyone, i have a 95 s14 and it recently started making a noise when i release the clutch pedal, but only when i am in gear. It's making a clunking sound that sounds like its coming from behind me. When the car is not in gear pressing the clutch up and down and no noise...it's a sr20det off of a s15 with 6 speed transmission if this helps...a friend of mines is telling me it's the differential making noise but just wanted to check with the pros first. Thanks in advance!!
MySXisSlowerThanUrs
Car: Toyota Mr2, Nissan 350z, 89 Piggy 240sx
Sounds like it would be the diff
slowsky
nooo i can't afford a differential right now. Also..i know this is gonna sound noob but do i need to get a diff from a s15 or does it not matter??
Dittoz7
Car: 1997 2f0WtY SE!
I Don't Think It Matters.
Open Diffs Don't Go For A Lot.
$50 Tops.
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
I doubt that its the diff, might be the transmission output shaft case bearing(or what ever they call it now). Cause it would only make noise when in gear. Making sense clutch released/engaged, turning input shaft, gear (selected) meshed, going to output shaft/tail shaft. From your description, I would say this is transmission bearing related, but not definite to only trans.
There is a way/steps to get a good idea of what could be the problem. But it's been couple of years since I dealt with trans diagnosis when I went to tech school.
As for Diff, get 95 or 96+ Infinity J30, its a VLSD meaning Viscous Limited Slip Differential, much better than stock S14 open diff. They are direct bolt in for your car, which will allow you to use stock axles. Older J30 VLSD are 5 bolt flanges/axles, opposed to 240sx 6 bolt. Make sure you get correct because there are ABS versions. With sensor in the front of diff reading of off pinion, some S14' are ABS and some are NONE ABS. Z32 N/A diff will work too.
Q45 and Z32 TT are a bolt in too, but require much more parts to make it work. Don't think this would be ideal for you.
GL
weadmttothetruth
Car: 95 240sx
Ive got a 95 to and its got the same thing. If it helps to diagnose it myne doesnt happen as much when im on the gas a bit
