Okay sil80, you can buy me an EBC, and if it works, I'll refund your money
I said myself building boost was a lot different than sustaining it...
But my turbo has NO MORE than 500 miles on it...I bought it freshly rebuilt--with a new wastegate--there's no possible way that the wastegate is malfunctioning unless its normal for these things to crap out after 500 miles of very mild use.
The WG actuator hose is connected to the only place it should be connected to, the compressor of the turbo. I never heard of connecting it to the manifold--I'm internally gated btw.
I'm measuring boost off of the INTAKE manifold, which is what counts, and which is where most people measure it off of...I don't care what boost it's at at the turbo, I need to know what exact pressure my engine is really going to see...
In any case, if I do indeed have a malfunctioning wastegate, which seems highly improbable, a T3/T04B in any case is going to be a better turbo than a T3 super 60. I'm only losing ~$50 on upgrading the turbo so if it turns out that the wastegate was the only thing that was bad, I won't be disappointed because I'll have a more efficient turbo.
We gotta stop post whoring sil80 :icesangel
