Help me with my 2871R sr20 build?
RPS13-NY
Car: 1991 RPS13
Ok, so i have a garrett gt2560R and was planning on using that turbo on my redtop s13 [stock motor] to get to 300hp, I've ben ordering parts to support that build, i now have: Tomei exhaust manifold, Isis 300zx MAF, Nismo motor & transmission mounts, waiting for my Ecu from Nistune, getting ready to buy Injectors, a wideband, and a fuel pressure reg...... and then i started thinking.. why try to go for 300hp maxing out the 2560 which i might not even achieve with that turbo [?], so I'm pretty much set on going 2871R, I'm aiming for around 375hp, so i believe for that to be achieved i need: rocker arm stoppers, arp studs, head gasket, JWT S[?] Cams, springs, retainers. and 650cc injectors? What else will i need? Will aftermarket internals be necessary? thanks.. just trying to figure out how long of a drop I'm going to be falling into this money pit lol :rotfl
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
What you should buy
Headgasket of your choice
ARP Headstuds
740cc injectors
JWT S3 Cams
RAS are a good idea
Springs and retainers arent necessary for the s3 cams, but you can if you want (reference JWT website if you want to read what they have to say about it.)
http://zilvia.net/f/tech-talk/124925-gt ... or-77.html
Reading this thread will give you more information than you need about the sr and gt2871. So read it and enjoy
Post your results when your finished
ludi
Car: ´90 Nissan S13 CA18DET
You don´t need cams, but it isn´t a bad buy. :) Here, the car from my buddy:
[youtube]http://www.youtube.com/watch?v=ghBcH-I9NRk[/youtube]
Greatings, ludi
badbob2121
^Thats a GT2871.86
I own and would recomend the GT2871.64, its will be much more responsive and still put out plenty of power
The .86 has a higher power rating, but it will have more top end than mid range.
I can hit 20psi on my turbo around 3650-3750rpm
and heres another video for you
[youtube]http://www.youtube.com/watch?v=RMuyXATr0Cc[/youtube]
ludi
Good numbers! :bigthumb: The .64 response faster, thats right, but it eats your stock gearbox like hell. :)
Dynosheet:
Greatings, ludi
RPS13-NY
Car: 1991 RPS13
ludi wrote:Good numbers! :bigthumb: The .64 response faster, thats right, but it eats your stock gearbox like hell. :)
.......that doesn't sound so good lol... how has your transmission been holding up since u put the 2871 in? [anyone with a 2871 can answer]
And i was told i dnt need a head gasket or head studs for around 375 hp w/ a 2871 .64..... thats false rite?
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
RPS13-NY wrote:And i was told i dnt need a head gasket or head studs for around 375 hp w/ a 2871 .64..... thats false rite?
It is a hit and miss. It depends how long your engine has been sitting in teh junkyard in Japan, Canada, etc. For insurance purposes get head studs and a metal gasket. :)
RPS13-NY
Car: 1991 RPS13
Gotcha.. Also im guessing JWT S3 is more ideal then S4, as far as lower rpm powerband? Also even if i get S3 should i get springs and retainers just to be safe?
badbob2121
My gearbox is fine....
and you can buy springs/retainers if you want to.
Im not going to buy them if that helps.. all the questions you have asked have been answered in the link i posted. You really should spend some time reading through it.
RPS13-NY
Car: 1991 RPS13
Gotcha, thanks ill keep looking into that thread
