help me with my 240 please
beaver
Car: 240sx
either find me a thread that can help if someone can tell me what im doing wrong ...
i have a 90 240sx.I'm doing the ka24de swap and i have a 95 s14 motor (stock) with a 93 s13 harness, ecu, mafs, and distrubitor .. and i have the s14 header to cat and an s13 catback exhaust ... i have spark , i have fuel , and air ..its still not turning over can someone please help me..
i was told to swap out the intake manifold to an s13 dohc and it should work and to swap out the o2 sensors and temp sensor and was told to play with the dizzy and see if its in right but i figure if im gettin spark then why play with the dizzy ..
someone please help me out im lost in 240 hell..my brain is fried i feel like im back in high school ...
Mr1der
let's see if we can't move this to where you'll get better help
480sx
Car: 1996 Pearl White 240sx
Well, assuming that your definition of turning over and mine are the same, it sounds like your starter isn't getting juice. Check to make sure your starter is connected to the battery properly. Check the ground, positive lead, as well as your signal wire. If that all checks out, make sure that when you turn your key to the start position, your signal wire gets power. Take a voltage meter to the smallest wire running to your starter, crank the key and see if you have power.
You can also 'hotwire' your starter to see if its good or not. Take any spare wire you have lying around your shop and connect it to the positive side of your battery. Next, take the other end of that wire and place it against the smallest terminal on your starter. This SHOULD 'turn over' your engine. If not, you have something wrong with your starter, as long as the power/ground running to it check out ok. At the very least your starter will click if you've done everything right. Hope this helps
beaver
Car: 240sx
ill try this ..tomorrow thanks
daedae5
Car: 1989 Nissan 240SX KA24E
Okay, well in similar fashion I have an '89 240 with a KA24E with a manual transmission and the motor is basically destroyed.
I was talking to a JDM distributor about get a SR20DET Blacktop from an S14 and was wondering if there was any way that I could get directed to a step-by-step swap guide...I looked throughout the forums but couldn't find this particular type of year swap.
I would appreciate any help that you can give me.
