Matt300ZXT »
https://forums.nicoclub.com/matt300zxt-u24145.html
Sun Mar 01, 2015 12:57 pm
So, I know everyone says it costs a million dollars to do one, you're giving up displacement, it's easier to do a VG30DETT, etc...
Help me out with a cost breakdown, I know that it's much easier to source parts and do one now than it was even 5 years ago. The car is a twin turbo.
Here are some things I have already:
Nismo 740cc injectors (brand new in box), that'll knock about $1000 off the price of the swap.
Precision t4 turbo with .68 hotside, so should spool fairly well on a 2.5.
Nissan chipped ECU, could resend the chip out to be flashed with different parameters to fit the RB25 (unless of course standalone is the only option).
Already have manual transmission, and would obviously need an RB bellhousing.
Wiring shouldn't cost too much, as I have a brand new unused Wiring Specialties harness for the Z32 I could resell and spend a couple hundred bucks on the difference to get the Wiring Specialties RB25/Z32 pre-made harness.
I also have a 1JZ and R154 that people have been emailing me with total boners to buy, at least the R154 setup, so if I were to let it go that's $1800 right there. That's pretty much the cost of an RB25 and a water pump/timing belt/gasket kit. Might even be able to trade the 1JZ for an RB25.
I'm not factoring in various other gaskets, silicone hoses, new rubber lines, etc obviously. But best case scenario (with procurring the RB25 through trading/selling 1JZ parts) am I missing anything below?
Motor-might be able to trade for, or at least purchase it with 1JZ swap sell parts
Trans-already have, need bell housing
Mounts-$409 (or $500 from McKinney)
Oil pan-$398
Cooling (radiator/intercooler)-$1048
Turbo-already have
Injectors-already have
Wiring-sort of already have
ECU-already have
Cross member-$300'ish unless I find a used one already modded
Drive shaft-$450 from McKinney
Downpipe/exhaust-can be covered after I get the engine in the car and started
Am I missing anything in there?
