2_Liter_Turbo »
https://forums.nicoclub.com/2-liter-turbo-u12924.html
Sat Mar 15, 2014 9:01 am
The clutch and pedal assemblies have only a two pole switch (the plug you see is for this, look inside, it has two pins for each side of the switch). Sensors provide feedback via changing a voltage signal typically, this is just a on/off switch like the ones you find for your lights in the house.
Things you need to complete a 5 speed swap:
5 Speed lower harness makes life much easier
Trans of course
Driveshaft
Cross Member w/ Mount
Shifter
Lower and upper shift boot (try to find the upper shift boot attachment ring to go with it)
Clutch master and slave cylinders (just go and buy new ones, they are very cheap)
Clutch master cylinder hard line. You can also buy SS braided lines, but the hard line is cleaner and OEM.
You can use the auto ECU with no issues.
Hole Saw and drill bits for the firewall. You are provided a template from the factory
Clutch pedal and brake pedal if you want the OE fit and feel. You can cut the auto brake pedal if you want to go cheap.
Flywheel & clutch of course. You'll also need the flywheel bolts (you can't use the flexplate ones) and the clutch cover bolts.
Clutch fork (if the trans doesn't have it already)
If I remember correctly, the sandwich plate between the trans and the block is different as well as the lower trans brackets that bolt to the block. But it's been awhile, so I could be wrong here.
I think that's all.
