Help Me
240dreams
Car: 240's
Alright, I was wondering what size spacers will make a stock set of s13 alloys look more snug. I already know the consequences about spacers so please dont bring them up. I also plan on adding Sportlines. Thanks in advance.
chmercer
wtf does "more snug" mean; why would you want to put spacers on your wheels if they already clear the suspension/brakes?
Exar-Kun
Car: 2005 350Z
wahooo. beat me to it!thanks -chet
chmercer
[asskiss] i learn from the best :D [/asskiss]
SmithSR
Car: 240sx
:confused: more snug? I also am a bit confused...
^^borrowed pic....factory fitment looks good to me!
C-Kwik
He is probably referring to the wheels being more flush with the plane of the fender and 1/4 panel.
240dreams
Car: 240's
thank you C-Kwik thats the word. People act like they're fuggin big and bad nowadays. If I can't get a strait answer don't even bother.
240dreams
Car: 240's
this is what i mean
Nismo_Freak
Car: 89 Nissan 240SX
Your gonna need something like a 20-25mm spacer to set out the wheels that far.
Jack up the car and slide your wheel to the edge of the fender. Have someone measure the distance from your hub to the mounting plate on the wheel (center round peice). That will give you an estimate of how wide a spacer you'll need.
I HIGHLY suggest just fitting wheels with a better offset and that are wider. Spacing out a wheel that far is dangerous unless you plan to get a set of the more expensive spacers that have their own secondary studs built in. Even then you need to check the lug nuts often.
240dreams
Car: 240's
thats a lot nismo freak thats a very reasonable answer.
