spacemonkey »
https://forums.nicoclub.com/spacemonkey-u17157.html
Sun Jul 10, 2005 8:05 am
2 things....
first problem..i was driving my car one night and all of a sudden it wouldn't shift into gear or barely move in neutral, i took it to the shop and they said it was probably the clutch, i bought the clutch he put it in the car drove for a little bit but the clutch pedal didn't have the pressure it should have for a stage 2 it felt really weak like it was going to die so i took it back to him 5 minutes later he drove it he said it didn't feel like this before so he parked it and then all of a sudden it wouldn't go back into gear so im back to square one..im thinking the synchros or something in the transmission is screwed up??
second question....The tech that is doing my clutch right now said that the throw out bearing is the wrong one (the clutch is a 3 puck stage 2 exedy), from what i remember the throw out bearing is just the bearing that you put on to the shaft, but the tech that took my old bearing out had a little metal shaft in it that looks like it's been pressed on, so the question is which one is the right one??
can anyone help??
