HELP ME! SR20DET wiring
EYEHEARTJDMS13
Car: 1990 Nissan 240sx S13
Okay from a KA24DE harness to an SR20DET, the two wires that are where the stock battery go I need to know how to wire them... PLEASE HELP!!! everything else is wired up and ready to go, I had it cranking without turning over prior to hooking them up.
Clawhammer
EYEHEARTJDMS13
Yea I found that but it doesn't explain what color goes to what from the KA to the SR between the two clips well if it does it confuses me alot.
Clawhammer
It doesn't get any simpler than figure 5a. I'm sorry.
EYEHEARTJDMS13
Can you sum up which colors and functions go to the grey clip and which colors go to the brown clip?
wackawacka
EYEHEARTJDMS13 wrote:Can you sum up which colors and functions go to the grey clip and which colors go to the brown clip?
Seriously? did you look at the chart?
The Chart "Sums up the colors" and the functions
EYEHEARTJDMS13
I understand it's simple but without them infront of me its hard to see how to wire the two clips with the descriptions, I ran out of daylight to finish it.
wackawacka
The chart does not differentiate which plug which wire belongs to. Cut your two SR plugs off the SR harness. Cut the similar KA plugs off the KA harness. Put the KA plugs /w a workable amount of wire up to the SR harness. Match up the colors according to the chart. Solder wires. Tape/shrink wrap.
Is that it? please correct me if im wrong.
EYEHEARTJDMS13
Ya I just went out and cut the end off now and have the KA clips and the SR clips in my hands trying to follow the chart. I'll give it a shot.
wackawacka
Just throw those SR Plugs to the side. Basically replacing the SR plugs with the KA plugs
EYEHEARTJDMS13
Yes that is what I am doing but the colors on the KA do not match my SR colors.
wackawacka
None of them do? Pics?
EYEHEARTJDMS13
wackawacka
Very nice pics. ok discard the SR plugs. Now compare the KA plugs to the SR harness where you cut the SR plugs off. You will connect the KA plugs to the SR harness
PS. Looks like you cut the KA plug wires a bit short. May be a b1tch.
EYEHEARTJDMS13
See my dilima?
wackawacka
I am pretty sure that some of the plug wire will need to be mixed. For example a wire off the KA brown plug may go where the SR grey plug was cut off.
EYEHEARTJDMS13
This is a pain I appreciate it, I don't see it working tonight, I need step by step for the colors this is horrible.
wackawacka
Ha. yeah. good old eastern standard time. Good work with those pics. Its simple though. Just color matching. Good luck
EYEHEARTJDMS13
Yea thank you buddy you take it easy.
Clawhammer
Are you serious? Of course the wires are different colors between KA and SR THAT'S WHAT THE CHART IS FOR.
Sell your car.
EYEHEARTJDMS13
Yea but the chart matches color to the same color so how can I match them? and for one I didn't do the first harness, if your not here to help then don't bother to comment. Whats your car run??? Bet I gotcha there?
Clawhammer
Got me where, what do you mean what does it run?
What do you mean you didn't do the first harness?
Start matching the colors, not all of them get used. B/R and BL/R BOTH go to the B/R on the KA plug. Match what's there and tape off the leftovers...
k00laid83
Clawhammer wrote:Are you serious? Of course the wires are different colors between KA and SR THAT'S WHAT THE CHART IS FOR.
Sell your car.
look man just follow the chart i was looking at those plugs and some of the wires match. i think theres like 4 to 5 wires that don't do anything. just dont expect that lets say the sr brown plug and the ka brown plug all the wires match up because some of the wires you'll need will be in the place on the gray plug. i dont know if that makes sense but if you see the wires match the same on the ka then most likely there right! what ever doesnt match doesnt get used.
k00laid83
alright man i dont know if you can understand this but i color coated it for ya! and just use your other pics to compare!
EYEHEARTJDMS13
Ya I appreciate it I finished it last night then crashed out, I was just confused a to why you mix the clips up but its all wired up, taped up and about to put them back on the main harness. Thanks to all that tried to help and weren't giving me a hard time. Hopefully she'll fire up no problem today.
EYEHEARTJDMS13
SHE FIRED UP TODAY!!!!!!! I'm excited!!!
k00laid83
hey man thats great! so you just matched all the wires so did that picture help bro?
EYEHEARTJDMS13
Yes the picture did help I really appreciate you taking the time to do that for me.
k00laid83
EYEHEARTJDMS13 wrote:Yes the picture did help I really appreciate you taking the time to do that for me.
hey man no problem.
Clawhammer
EYEHEARTJDMS13 wrote:SHE FIRED UP TODAY!!!!!!! I'm excited!!!
Congrats! It was pretty exciting when mine started first try after I did my harness using that how-to on FRsport.
