eazye2000 »
https://forums.nicoclub.com/eazye2000-u30064.html
Thu Mar 01, 2007 6:20 am
Yeah, just run a ground wire from the Manifold, to the Chassis in the front. I ran 3 grounds from the engine to the chassis just to be safe. And 2 gauge isn't a bad idea, but 4 will get the job done. Just make sure you use at least 2 gauge in the trunk for the ground. And I would recommend grounding it to the bolt in the back where it connects the floor to the frame thing back there. That bolt should stick out and be noticeable.
At this rate, I'm gonna be poor... but that's my $.02 anyways. lol
